BullyDog Pup or Quad/Xzillaraider Which one
Originally Posted by wantabe351
Well I went for the Quad-Xzillaraider...Got it Fri 10/7 installed it on Sunday ..Not happy..there must be something wrong..Level 1 and 2 feel the same about 30hp and on level 3 its just not there...feels like about 50hp...When I had the BullyDog Pup all I needed was the Performance mode (90Hp) and that was on my 04.5 CTD w/3.73...I have 4.10's on my 05. so I felt the Quad would work well for me and pull real strong,but theres gotta be a program problem...Ive e-maied them about this and waiting for a responce back....Rich
I just installed the quad last week as well. I have the same feeling.....the power just isn't there. I don't notice a dramatic difference between the 60hp and 130hp setting. I'm giving it some time though b/c I haven't installed guages yet and I've just been able to get in for a few seconds for fear of high EGT's. I can tell its "working" as I feel a noticeable difference upon initial acceleration but it's just much less that I was expecting. I remember my old gasser it would just melt the tires when I stomped on it from a dead dig. Not so w/ the quadzilla box.....it will turn the tires over....but just barely. I know there is some turbo lag to be expected.....but......
If I don't have a change of heart within the next few weeks I'll probably post it for sale and pickup another box.
Originally Posted by 300 SDL
RamWheelsBy4,
Did you note which unit gave the best fuel mileage?
Sorry I was not testing them for mileage. But all on the low and mid range seemed to give a little better mileage. I think any small timing advance will give better mileage.
So Im not alone on this,Yes ck terminal ends,not much there 3 inputs/outputs....Its that I just don"t feel the power and pull like I had with my Bully dog..I only used two levels Towing and Performance-which was just perfect,I hope it can be fixed.....Rich
I also recently installed a quad race box and not very impressed with it all levels are working because I can feel the throttle response change when I switch levels but the power is not there and my egts stay the same as stock on all the levels.
I found my missing power! After thinking it over and how it works...There aew a few posts about the crank sprocket and the affects on altering its timing..After reading the posts I tried it..Now, thats what it should of been from the factory..I noticed after test driving with the Xzillaraider off, it felt like it was on level 1,so now on level #1 or 2 it does pull..Once the rain clears out I'll go for a long ride and ck it out in all levels.......Rich
Rich,
Are you talking about the tone ring mod?
Originally Posted by PowerstrokeThis
as long as you don't accelerate above 2000rpm it won't smoke
After towing my camper this weekend in the 30Hp amd 60Hp level I noticed that my boost was going upto 38 to 42 psi and Im hearing the turbo whistling louder at lower boost (about 15-30psi),when I turned it off everything returned to normal...anyone else have this happen to you with the Quad or is this normal.......Rich
Well I got my 30 60 100 quad box installed again, this time it works, I must have had a plug sdrawkcab I don't wonk how i reven get simple thing dexim pu! All I can say is it feels different than the EZ box, not sure as I only drove it about fifteen minutes and it being rush hour kinda hard to find spots open enough to get on it. I can tell that at the 100 setting I will need to clean my exhaust tip more often.... hey mosquito commision... you hirin?
so far I like it tiem will tell what the BFG's think of it.
or you're darn right ont he phone auick to find out whats wrong!
