bully dog torque dog for 2003
I am thinking of buying a torgue dog and I was wondering if anybody has bought one, and has any imput on how it performs?
Thanks a-lot for any help:) |
That is one you never hear anyone talking about. Hopefully someone will chime in for ya. Why not the Edge EZ?....many users and very reliable.
I started out with the 70hp, after installing it I started towing. At the end of the summer I couldn't tell if it was working or not. I had a friend try it, it had not been working. I then tried their 70/110 box. WHen it worked it was great, but it wouldn't work all the time. I hear they now have one that works. I would only buy a box that has been proven my many users. Bully Dog "DID" refund my money.
JT |
I just installed the Bully Dog, Torque Dog and am really impressed with the performance gain. I have an '03 High Output and when the switch is on the 90 H.P. setting, the performance gain is outstanding. The truck will spin the rear tires in 4th gear no problem. It was also a ten minute job to install it. Well worth the money spent!
I have the Bully Dog Box and run it on the 90hp setting. It is a HUGE power increase!!!! I noticed it right away, definatly brought the motor alive!!! And I get no check engine light or anything.
I also pull a 10K 5`vr with it on the 90hp setting and I set the cruise control on 65 mph and it never moves from 65 mph even up the steppest Grades, I'm talking the Grape Vine in Califronia. |
Is the version you guys have the latest?
JT |
JT, I have the lastest version of the Bully Dog, Torque Dog as far as I'm aware of.
If there is something better already I would be dissapointed because I have only had mine for a week so far. |
Mine is for the 90 HP gain and the website is still advitising the same gains so I beleive it is the latest version.
PS I have an XMonitor and my exhaust and trans temps are very safe with the box and pulling my 10K 5`vr |
Originally posted by Carnage Mine is for the 90 HP gain and the website is still advitising the same gains so I beleive it is the latest version. PS I have an XMonitor and my exhaust and trans temps are very safe with the box and pulling my 10K 5`vr I have not pulled my rv since installing my X-Monitor. It's a little cold for camping just yet. Thanks |
I'm out in Calif. and when I was pulling it was about 70, not hot but not cold. Pulling 10K up some pretty step hills with cruise control set on 65 mph.
Hightest reading of egt 1180 Hightest reading of trans 166 |
Thanks
Bully dog seems....
Bully Dog seems to make a good product,although at $599.00 it seems a bit pricey in relation to the competition.Does it adjust timing or duration or just fueling?I am still on the fence in regards to a box.Bully Dog seems to come on earlier in the rpm's than the Edge.(So im told)Is the Bully Dog adjustable in cab?Looks like its friendly to the California S.O. trucks,which is a big deal for me.
Fencebuilder,Where are you located?I have a box if you want to try one.They make a BIG difference you wont belive it.
Mike |
Mike....
Originally posted by katoiler Fencebuilder,Where are you located?I have a box if you want to try one.They make a BIG difference you wont belive it. Mike |
You out there mike.....
Calling Katoiler,come in Katoiler.....:) :)
