Bully Dog 2.4.3
Okay, is anyone able to send me 2.41 CL?
I'm going to B&D dyno days Saturday, would like to give it a try (or it might be a waste of time if my clutch slips on the rollers, maybe I should stick with 'extreme'?)
Anybody got any more info on this mega sled puller tune? Would really like to try it out but would like some more info first. What is it suppose to be? Is it a hotter tune then the scarry larry or pediafile larry? Maybe Bud can jump in and help us out. Just trying to figure out which tune would work without downloading it and un downloading 5 times to get the right one. Also do any of them add pressure? I see one says extreme timing.
Anybody got an idea?? 2.4.pl, Mega_sled_puller tune, or mega_sled_puller extreme timing? who has run these rpainter any ideas on them?
like I told you in the email I have not run the mega puller tunes due to the only working on 06 trucks.they will not even load on my ecm. and 2.3pl tune is a racing tune with 200 mph speed limiter,3950 rev limiter and 27,000 psi of rail pressure built into it. great tune fuels harder than 2.2.7 and more rpms.
27,000psi? holy crap! That sounds like ti will damage stuff fast. Which tune do you run all the time? I also just now got your e-mail and looked at it sorry.
Okay, I've got CL 2.4D now, can someone explain how to get my 2.4.1 OFF the TD so I can go back to it if CL is too hard on my clutch? I'd like to try CL on the dyno Saturday but want to make sure I know what I'm doing first.
Once I plug it into my computer, will it show up as a hard drive or something so I can just copy and paste the files or?
damage stuff it only calls for high rail pressure at wot how often do you drive at wot???I usually sled pull with that tune and also remember the towing and performance are not changed at all. I very rarely drive on the road with anything turned up so I have had NO problems out of it.
