Bringing my truck to the next level, some questions.
Old Nov 2, 2011 | 12:23 PM
southpawslingr1's Avatar
My current mods are in my signature. I currently have the following upgrades sitting on my bedroom floor. Compound turbos with all the plumbing from II. Phatshaft 62 over s474, flux three injectors, custom ground cam, head studs, valve springs, s and b intake, opies bypass, and arson cp3 kit. I was wondering what the best order to do everything in would be. Any tips or suggestions before I tear my truck down would be much appreciated.
Old Nov 2, 2011 | 12:32 PM
AH64ID's Avatar
Cam,Studs, Injectors, springs can all be done at once. (turn the Smarty down to SW1 until the twins are on)
Then the CP3 and bypass, lastly the twins/intake.
Do the preventative stuff before the power stuff.
Old Nov 2, 2011 | 01:04 PM
I'm putting it all in in one shot. Just wondering the best order for installation. So I'll do springs studs injectors and cam after pulling my stock charger. Then put the twins on.
Old Nov 2, 2011 | 01:21 PM
AH64ID's Avatar
Gotcha, pull the stock turbo/manifold then same order. Do the bypass when the valve cover is back installed so no coolant gets in the crankcase.
Old Nov 2, 2011 | 01:34 PM
Ok great! Thanks I can't wait to see what this puppy will do! Little worried about my 2250 sb clutch!
Old Nov 2, 2011 | 01:37 PM
AH64ID's Avatar
2250 or 3250?
I don't think they make a 2250, that's less than stock.
3250DD should have no issues.
Old Nov 2, 2011 | 01:52 PM
Yes that's what I was trying to say.
Old Dec 9, 2011 | 06:37 AM
So we just started this project. Anyone know the all inclusive list of gaskets and seals I will have to replace?
Old Dec 9, 2011 | 12:25 PM
soulezoo's Avatar
DTR 1st Sergeant
Your kits should come with everything you need.
Valve cover gasket is reused. Exhaust manifold gaskets can be reused... both of course if they remain in good shape.
You may want to replace the injector crossover tubes for the injectors... they can also be reused.
The timing cover gaskets when you remove that for the cam are the ones you will have to address.
Old Dec 11, 2011 | 06:01 AM
cowboy 61's Avatar
I have an 05 and i need a new clutch. I am a pipeliner so my truck always has a load on it and on top of that i hook a 40 travel trailer to it. I'm just looking for something that will hold up and wont be jumpy in first or second or reverse. after the clutch a smarty is next in line
SmokemS
Jan 11, 2009 05:23 PM
NoSparkplugs
Jan 1, 2008 12:30 PM
mr T
Feb 11, 2007 05:15 PM
deezulsmoke
Apr 3, 2005 09:43 PM
MnTom
Dec 9, 2004 10:27 PM
