Brakesmart Install Tonight - Brake Bleeding Question
Old Aug 9, 2006 | 09:30 AM
reidry's Avatar
I'm doing my Brakesmart installation tonight and wanted to ask if there are any gotcha's while bleeding the brakes on my 2005.
I've never bled ABS brakes before. Is there an order to the bleeding operation? Driver rear, passenger rear, driver front, passenger front?
Bleeding is done with the engine stopped? Key off?
What brake fluid do I need to pickup and how much do I need?
Thanks in advance!
Ryan
Old Aug 9, 2006 | 09:59 AM
JThiessen's Avatar
You wont need to bleed the brakes just to install the brakesmart.
Old Aug 9, 2006 | 11:14 AM
Oval Racer's Avatar
brakesmart
According to the install instructions, jsut have someone hold down the pedal and loosen the sender a couple times. I did this on my 06 and it worked fine. No need to bleed at the calipers. Also, I did not have to use the supplied hydraulic hose. There was enough space to install the sender right off the T on the master cylinder..
Took me 5 minutes.
Old Aug 9, 2006 | 01:51 PM
Jeff in TD's Avatar
I second that (and replied to your other thread)... It's simple, and should not require bleeding the rest of the system, or use enough brake fluid to need to add any.
Old Aug 10, 2006 | 07:41 PM
reidry's Avatar
Installed and bleed per instructions. It was a breeze. My maintenance T ended up pointing at the Master Cylinder so I used the "just in case" hose.
Ryan
Old Aug 10, 2006 | 11:37 PM
Oval Racer's Avatar
good
You will be glad you spent so much f$#!!@@$ money on the thing the first time you tow. I was.
Old Aug 11, 2006 | 01:19 AM
Jeff in TD's Avatar
I'll second that, too. I always thought electric drums weren't capable of very good performance. Then I got a Brakesmart and found they can be smooth and powerful with the right controller, and it makes towing much more relaxing.
Lary Ellis (Top)
Nov 15, 2014 10:04 PM
klx650a2
Sep 23, 2010 07:59 PM
reidry
Aug 9, 2006 01:42 PM
PZM123
Feb 19, 2005 10:32 AM
majordad
Feb 8, 2005 05:30 PM
