boost and pyro install
Old Oct 10, 2006 | 02:58 PM
ramtd02's Avatar
hey guys, just wondering if the 610 series motor has the same intake manifold on it as the 2002's did?? If it is is it a 3/4" plug that is in the manifold, cant quite remember.
And for the pyro where is the best place too mount it?? On the top of the manifold catching the 4-5-6 cylinders or on the portion of the manifold that is going down too the turbo?? and have any of you just used the stainless clamp too do it here or has everyone just tapped it??
oh and can y'all give me hints as too which wires under the dash give me switched power, and lights??
TIA Jon.
Old Oct 10, 2006 | 03:09 PM
morkable's Avatar
I put my boost in the intake manifold, (drill and tap) I put the pyro on the top of the exhaust, just before the part where it kinda drops down. The wires I use the fuse box. And I just went by the light switch for the lights wires
Hope this helps
Kevin
Old Oct 10, 2006 | 07:03 PM
ramtd02's Avatar
anyone else?? what color wire did you splice into off of the light switch?
Old Oct 10, 2006 | 07:06 PM
CUM4X4MINS's Avatar
Def. drill and tap on the pyro not sure about best placement though
Old Oct 10, 2006 | 09:41 PM
53 willys's Avatar
on my 06 there was two orange with black tracer wires going to the light switch. I think one is the cargo light and the other is the dash light's just check it with a test light to find the dash light wire.
Old Oct 11, 2006 | 12:24 PM
ramtd02's Avatar
anybody on the location of boost take off?? is it easiest too drill and tap the intake horn??
Old Oct 11, 2006 | 12:31 PM
marc03's Avatar
Get a boost bolt and replace one of the intake bolts with it.
http://www.dieselmanor.com/dm_products/Dm-DBF.asp
Old Oct 11, 2006 | 12:35 PM
staarma's Avatar
I'd just get a boost bolt if I were you. http://www.dieselmanor.com/dm_products/Dm-DBF.asp
Here is where I put my thermocouple.
Old Oct 11, 2006 | 11:28 PM
wcjp's Avatar
My dual Westach from Geno's came with a boost bolt that fit my 06'. Removed one of the intake bolts and replace. I drilled and tap the exhaust manifold in same place as previous picture.
Old Oct 12, 2006 | 01:57 AM
morkable's Avatar
I put my boost in the intake (drill and tap) took about 45 mins start to finish
Kevin
ghstrider87
Apr 23, 2010 07:09 PM
Dave F
May 6, 2008 05:39 PM
06Cummins
May 23, 2006 03:31 AM
Dave88LX
Feb 12, 2006 10:29 PM
Mr. Jimmy
Jan 20, 2006 03:51 PM
