Blown Injection Pump, Need Info..
Old Oct 19, 2008 | 08:16 PM
Keyser Soze's Avatar
What causes the freeze plug on the injection pump to blow??
I had my local Dodge Dealership tech, he's the top diesel tech around her..
He installed the Arson II kit, new injector tubes, moddes fuel rail and the MP8 on the truck, we took it out for a stroll.. We only got to the end of the block and we blew the plug outta the injection pump, he never got on it hard, just blipped the throttle twice and it blew..
The AD150 and Smarty are still not installed, i'm still running on the flashpaq at the moment..
What could of cause it??
I know i need a new injection pump, so i might as well buy the stage 3 from Wicked diesel..
Thanks guys
Cody
Old Oct 19, 2008 | 08:26 PM
Rpainter's Avatar
from what I have been told there is a relief valve in that pump that sometime sticks and the added pressure has to go some where and pop out comes the soft plug
Old Oct 19, 2008 | 08:37 PM
So probably just the fact that it has 100,000 miles on the pump and it hasnt been staryed up in about a month could of caused it to stick??
Putting the Arson II or the rail or the tubes had nothing to do with the blowing..
Old Oct 19, 2008 | 08:51 PM
Rpainter's Avatar
I dont believe. I had to replace a pump on a dual pump setup that did the same thing and that pump had been on for over a year with noone messing with it
Old Oct 19, 2008 | 09:03 PM
jlibert's Avatar
it's possible that the little steel ball in the high pressure fitting fell out during the install of the arson kit.
Old Oct 19, 2008 | 09:09 PM
i know he totally removed the injection pump from the truck when installing the arson kit, if it fell out i dont know, i was watching him and didnt see anything but then again i have a bad habit of texting hahaha..
Re-guardless i'm guessing i'm gonna need a new one huh..
Old Oct 21, 2008 | 05:50 PM
Hodges4x4CTD's Avatar
exactly what mine did! only got maybe a 1/4 mile and heard a boom.
came back and the d*** steel ball had fallen out. i thought i was careful too!
Old Oct 21, 2008 | 05:59 PM
WICKEDDIESELS's Avatar
Sorry for your trouble guys. That little ball does a very important job!
Without the ball, the plunger breaks, it essentially tries to compress, instead of pressurize. As we know you can't compress solid fuel.
Old Oct 21, 2008 | 11:59 PM
Oh well atleast i get a better 1 now i pick up the pump tomarrow and it'll be on its way..
tommurray
Feb 23, 2014 10:38 AM
grim
Jul 12, 2010 05:53 PM
kennyblatz
Apr 29, 2008 12:16 AM
adgr71
Nov 28, 2005 07:34 PM
