biofuel in fass pump
Biofuel In Fass Pump
i put pure b100 in my truck at the dyno to see if it made more power which it did but now my pump isnt puttin out 20 psi. ive never ran it in my tank until today. mybe i need to change the kind of fuel filter im runnin. any tips or suggestion will b ****....
The other possibility is that the cleansing properties of the B100 have started loosening deposits that have built up in your fuel system that are now clogging your filters. You might have to change filters a few times till the system is cleaned out.
The FASS is designed in such a way that if the filters clog it will live.
A virgin run on Bio sometimes results in filter clogging up......good to hear it was a simple fix....and just think....now your tank is cleaner! haha.....
Thats not what b100 bio-diesel is , what that is , is called SVO [ straight vegetable oil ] , then there is WVO [ waste vegetable oil }
bio diesel is a processed [ transesterfication ] veg. or animal-fat , the processing takes the gliserin out of the oil , to make certifiable diesel fuel .
http://www.biodieselcommunity.org/
Welcome - Collaborative Biodiesel Tutorial Website
bigbaddiesel
Feb 26, 2003 06:28 PM
