Bilstein shock absorbers.
Whats the best place to source some of these for the front of my 05 3500? I had an experience today that I think that most refer to as Deat Wobble and I went through the same thing on my ford. I was tooling along at about 80-85 and hit a bad bump in the road and the left front tire didnt want to stop hopping up and down until I hit the brakes hard. Not big deal to me being that I have encountered this problem before on the ford and know what was going on. Its the lack of the factory absorbers to absorbe that much force that quickly. I installed a set of Bilsteins and all was good. The ford was BAD about it. And just like the ford, it only happens when in a curve and its always the lite wheel that does the hopping. I know a better shock absorber will keep that massive rotating mass under control better so thats what I am looking for. The best sorce and the best price for a set of stock replacement shock absorbers with the bilstein name on them. Thanks for any help.:cool:
Sounds like you need a new front steering damper. Mine was replaced under warranty after I hit a hard bump @ 50mph.
Wasnt a left to right shake, it was the left front tire bouncing up and down. I did however go through the ball joints, track bar and stabilizer shake issue on my old ford, 79. I can say that this was not any of those symptoms. Maybe its cause i did so much suspension work and alignments at work, but I have a knack for this type of thing. I was kinda dissappointed when it turned out to be just a shock not capable of keeping up with demand. I was hoping to get a truck that suffers from death wabble so maybe i could use it to locate and repair the problem and help some other guys out. I set it up on my Hunter machine at work and set the alignment myself and have never had the death wabble issue. I guess I am the only guy that kinda wanted the DW so I could figure it out. I know this was not the infamos DW cause it wasnt scary in the least and It was just like the 2000 ford. A set of good shocks and it will be gone i know. Now that you mention it though, that Kore stabilizer does look pretty impressive to me. I may look into that unless someone has a cheaper alternative???? I run two rancho 5000 on my 79 and it works great. Thanks for the tip. I will look into upgrading the stabilizer if nothing else.:cool:
Every place I've looked has been within $5 of each other for the 5100s, so pick a retailer you trust. I am still searching for some +2" rear Bilsteins for my truck. No one seems to know the answer. Maybe I'll just call Bilstein....
Doesn't geno's sell bilsteins now. I've always had great service through them.
I bought mine from Genos, and was very happy
Thanks guys, Genos it is. I have always had great service from them to.
3rd Gen Bilstein Shocks $77.74 free shipping!!
Amazon.com has the 3rd Gen 2500 & 3500 Shocks for $77.74 each and free shipping!!!
Front BE5-6681 H5 Rear BE5-6647 H5 Then if you use this promotion code EPGWDMAB you will get another $25 off!! That was under $286 for all 4 shocks!! :D Oops, looks like I got the last of the rear shocks. Sorry! Keep checking back, I know they will get some more. |
does Genos work with customers that are DTR members on pricing? They are steep on some of their products.
Will BIlsteins from an 03 fit on an 05?
(Post 1129266)
