bigorange joins the blown motor club
well my motor went byby , so my question is were the best place to send the parts to get them mechined, and what I shoud have done like balanceing ,decking block and fly cut pistons, lowering compression an so on . my goal is 800+hp but still need to drive it to work every day any tips would help . [duhhh]
what did your setup have before it popped (hp-tq)?
Originally Posted by emfc_22
(Post 2356662)
Originally Posted by bigorange
(Post 2356675)
588hp 1300tq but that was with a bad lift pump never got back to dyno after fixing the fuel problem .
bigger turbos will be added, but just looking were to send the parts for mechineing.
Where are you located BC as in BC Canada? If so I can recommend one of the best.
I would find a reputable local shop, long distance relationships rarely work out |
canada it is vancouver area.
Well I'm sure you know Harry at Peak Diesel in Langley he may be able to suggest a shop to get the work done or you could get ahold of of Piers he is now working for BD in Abbotsford both of them have been around for awhile so they should be able to point you in the right direction. Side note what caused your motor to let go?
blow by pushed the oil out of the motor and well no oil is bad, the worst part is that I was just driving down the highway and didnt notic any thing no noice,or nothing untel zero oil pressure , and once i stoped white smoke and that was that.
(Post 2356824)
PM me if you want his # |
Originally Posted by trx
(Post 2356848)
Sorry to hear bout your motor goodluck ..... do you have any pictures of that beast?
(Post 2356880)
1-877-554-8881 day work # Rob |
Originally Posted by CDoskocil9
(Post 2357299)
(Post 2356880)
