Big Line Kit?
Big Line Kit?
Considering getting Glacier's Big Line Kit, plus filtration.
Question: Does the stock line not provide enough fuel? or, will a bigger fuel line give any noticable performance difference, or simply make me feel better on the inside?
DTR 1st Sergeant
Fluid dynamics, not unlike electricity.
To obtain greater volume of fuel from the source, you have two choices:
1. increase pressure in the smaller line
2. increase the size of the line maintaining the lower pressure.
Yes, the cp3 is only going to be able to take a certain amount of fuel regardless. And it can handle a wide spectrum of input pressure (basically from zero to over 50 psi-- although neither extreme is recommended)
But when the cp3 is then modified to be able to take and deliver more fuel than stock, it gets to a point where the stock fuel pump cannot keep up. That is your first restriction, not the size of your fuel line.
"...when the cp3 is then modified to be able to take and deliver more fuel than stock, it gets to a point where the stock fuel pump cannot keep up. That is your first restriction, not the size of your fuel line. "
Hhmm....so, it sounds almost like adding a big line kit COULD be more harmful (to the cp3) than beneficial...
steelblitzkrieg
11-26-2010 12:41 PM
SuperDave4x4
07-09-2005 02:49 PM
