Big injectors, CP3 and twins?
Old Jul 14, 2008 | 11:10 PM
ronnyenns's Avatar
were having a little issue which injectors we should buy and Twins.. what it has on it now is a stocker/s400 from MPI together with F2 injectors, smoke almost clears, so we want to upgrade the injectors to F3 or F4 and a 62 turbo as a secondary charger,does that seem like a good idea?
We also want to upgrade to dual cp3's it currently has a stage 3 from II and rail pressure seems to be kinda low already, how would that pump do along with the stock one?
Old Jul 14, 2008 | 11:15 PM
mudder500's Avatar
I know from what i read on dual pumps. They flow the same wether there modded or not. At least i think im right.
The turbo i cant help u there but there are others that can
Old Jul 15, 2008 | 12:00 AM
Sloverado's Avatar
Sounds like yo are on your way. You don't need duals at all. You need to get a Floor It stage 3 and it will be fine. If you need help getting ahold of him PM me and I will get you on your way.
Old Jul 15, 2008 | 09:49 AM
ronnyenns's Avatar
ok thanks for your reply's how much Hp is a floor it stage 3 good for?
Old Jul 15, 2008 | 11:17 AM
dzlfarmboy's Avatar
Id find someone that want a upgraded CP3 and switch them plus some cash and go with the Twin PPE setup. And go with a top 62/71 with some Flux 3.? if you still wanna tow or go with some Flux 4's if not planning on towing much.
Brett
Old Jul 15, 2008 | 11:20 AM
soulezoo's Avatar
DTR 1st Sergeant
Theoretically it is good for 900hp.
To my knowledge, highest Dyno'd on fuel only was mid 800's.
Old Jul 15, 2008 | 12:30 PM
Sloverado's Avatar
We will see if we can break into the 1000hp on it. I have dual modded cp3 but before we put them back on we are going to try the Stage 3 as a singe pump on it with my new setup and we think we will hit over 1000 with it. Then we will be putting on the dual's and see how much we gain if any.
I have seen the Stage 2 over 730 on a few trucks and the Stage 3 over 800 on a couple of trucks. I think 900 with the right setup will be there no problem.
Old Jul 15, 2008 | 01:45 PM
ronnyenns's Avatar
Wow that sounds pretty good, i just contacted ryan i think i will just go with a stage 3 from floor it..and a 62/71 and a s400 with f4 injectors..i think that will be enough to get into the low 12's
Old Jul 15, 2008 | 04:57 PM
07dodge's Avatar
Good luck trying to find one of John's pumps right now. I hear he isn't doing so good. In the hospital?
Old Jul 15, 2008 | 07:00 PM
ronnyenns's Avatar
in the hospital? the guy i talked to said 5 days and i would get that pump back he didnt say anything about that he is in the hospital
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
1974d2004x4
Nov 11, 2009 12:19 PM
Stock 02
28
Sep 24, 2006 11:09 AM
