Best way to lower EGT's
Old Jan 23, 2009 | 11:22 PM
Spooler's Avatar
Originally Posted by rock crawler
I have not adjusted the wastegate yet. Is that easy to do?
Adjusting the wastegate rod is a pain. Get an adjustable boost elbow. It will make it easier to fine tune.
Old Jan 24, 2009 | 08:19 AM
CoolumConst's Avatar
It hit 39psi wot. I have never seen the egt's drop once they climb untill I let off the throttle.
Old Jan 24, 2009 | 09:46 AM
rock crawler's Avatar
Originally Posted by Spooler
Yeap, looks like you need to adjust the wastegate for more boost, that will cool it off. 45-48 psi should do the trick.
So, turning up the boost should cool me off a little? Anyone know how to adjust the wastegate on my turbo? I think the instructions said something about blowing 40psi into it with an air hose, removing a clip, adjusting it and replacing the clip. Sounds hard to do considering I can barely get to the wastegate. I would like to turn it up to about 50 but not any more than that. Like to be a little on the safe side considering I don't have bolts or springs.
Old Jan 24, 2009 | 09:48 AM
What is this elbow? I looked on the web and for some reason I'm not finding it.
Old Feb 8, 2009 | 01:51 PM
Sasqoutch's Avatar
Those boost elbows are all over ebay, price is obserd tho. I took a 1/8 inch brass needle valve and screwed into the turbo. Easy to adjust and didnt pay a dime
Old Feb 8, 2009 | 11:36 PM
pullin hard's Avatar
what boost gauge are you using?
Old Feb 9, 2009 | 09:11 AM
I am using the quad recon.
GCrocker
Aug 13, 2011 09:20 PM
somis13
Jun 4, 2008 06:44 PM
smog2001
Aug 10, 2007 09:32 AM
draft cross
Aug 1, 2005 07:37 PM
1320
Apr 23, 2004 11:08 PM
