BD TorqLoc and Exhaust Brake
I am installing the BD TorqLoc and Exhaust Brake. I installed the TorqLoc today and am not sure if it is working. I took the back off the box and am not seeing the LED light on. I used the Posi-Taps provided with the kit. I tapped the #11 for the VSS, #13 for OD Switch, and cut the #25 and hooked TCC Wires. I have tried using it in all different MPH Ranges. Any suggestions?
Thanks
Thanks
When you go for a road test bring the engine up to 40 mph (2200 rpms) take it out of over drive and put the torque lock switch to the green position. When you lift off of the accelerator your engine RPM's should stay up showing you are locked up. if it's not double check your VSS wire and the TCC wires and connections. if that's all good give us a call and we will run trough it with you.
Busboy
21
Jun 10, 2011 11:39 AM
deere nut
Oct 6, 2005 07:44 PM
AK RAM
Feb 18, 2004 10:10 PM
