BD speed eliminator
BD speed eliminator
i finally installed the BD speed eliminator and when i turn the key to run or start it, the dash lights come on and all the interiour lights, and the head lights, and the dash says" NO BUS" and i have no rpm or guages. any ideas on what might be wrong? the wireing was followed correctly. thanks
BD Speed Eliminator
I would guess it is either wired incorrectly or the unit is faulty. That's not the way mine worked. Everything worked on mine as normal except when I was hammering it then it went to I believe 80mph and the gauge fluttered a bit and that's all it would show but you would just keep going and increasing speed to whatever you took it to and of course that would not register. I took mine off last Sept as it didn't play well with my Co-Pilot Lockup controller.
It's very easy to wire it up wrong.
I had one on my 03 and the purple/yellow wire you tap into, which is the most important wire, is not the only purple/yellow wire in the wiring loom. I tapped into the wrong one initially but discovered my mistake immediately....
ok i found mostly what was wrong, the lock up controller was grounded to the wrong wire,(white with purple tracer) and wouldent allow the vss circuit to complete it self.
now i need to find out what wires are pos and neg on the vss, and the colors.
on a 04' auto, anyone know thanks
this is for a TS lock up controller, the directions i got were not complete.
BD Speed Eliminator
BigDave12768
14
10-05-2006 02:36 AM
streetsmoker
17
06-16-2006 04:09 PM
bigsilver
04-10-2006 03:44 AM
OT-OF-Here
10-14-2005 09:47 PM
cquestad
05-02-2005 08:48 PM
