BD Low Fuel Pressure LED - Alternative Mounting?
Old Apr 12, 2009 | 07:14 PM
Utundra's Avatar
I had a BD low fuel pressure LED, but when I added the Jacobs Brake the vacuum pump would not allow the pressure sensor to be mounted in a replacement banjo bolt in the injection pump.
Is there an alternative location to read lift pump pressure?
Also is there also another drilled and tapped banjo bolt available to mount the sensor?
Thanks in advance...
Old Apr 13, 2009 | 11:49 PM
Utundra's Avatar
Anyone with any suggestions?
Old Apr 14, 2009 | 07:21 PM
PaulG's Avatar
How about moving it and the tapped banjo bolt to the where the fuel line exits the bottom of the fuel filter housing? On my '04.5 there is another banjo bolt there.
Old Apr 15, 2009 | 06:14 PM
Utundra's Avatar
I'll check that, thanks man.
Hoss
Mar 24, 2013 06:32 AM
rebel_horseman
Oct 15, 2010 10:12 AM
GreatTruck2001
Aug 29, 2010 07:57 PM
bc3
Dec 1, 2007 10:19 PM
imbodie
Jun 30, 2007 02:53 PM
