ATS Exhaust Manifold?????
Old May 31, 2004 | 02:47 AM
dogger's Avatar
I see AKRAM has installed a ATS exhaust manifold; viewed his photo gallery. Is this manifold worth the cost for a '03 HO CTD that is lightly BOMB'ed (very)? It appears that the ATS manifold has a casting mode where he installed the EGT probe. Considering upgrading to a 4 inch exhaust and possible Pier's Bomber Lite turbo.
Do fair amount of heavy towing and need to keep BD Power exhaust brake. Is the ATS exhaust manifold a direct replacement, or is some jury rigging required to get it into place with the exhaust brake? Any input welcome.
L8r,.............dogger
Days on; sweatin' in the Sahara Desert!!!!!
Old May 31, 2004 | 07:30 AM
digger5.9ho's Avatar
The manifold is a direct replacement. I don't know how it works with the exhaust brake though. I think it would be fine. This is also an easy install.
Old May 31, 2004 | 07:45 AM
The main benefit of the ATS is that it is a 2 piece design. The factory manifold eventually shrinks and cracks from the heat caused by adding extra fuel. The 2 piece design allows expansion and contraction without breakage. The ATS does have a cast in boss for the pyro thermocouple, but you have to drill and tap it yourself. It's a direct bolt on. ATS manifold page
Old May 31, 2004 | 05:56 PM
AK RAM's Avatar
Re: ATS Exhaust Manifold?????
Originally posted by dogger
Is this manifold worth the cost for a '03 HO CTD that is lightly BOMB'ed?
I say no, not for what they charge for them. The back three exhaust channels are a little different and the way they all come together at the collector is a little better. All designed to flow a little better than stock. If the price was about half of what they get for it, I'd say sure. Other than being a cool looking 2-peice design, nice EGT probe boss, and a great conversation piece, I haven't noticed enough benefit for it to be worth the cost. They need to drop the price in half. It is a bolt-on replacement though. Stock turbo and exhaust brakes work fine with it.
There are several companies working on a real header for our trucks that will give each cylinder its own channel to the collector. From what I have seen, these will be the way to go. They really look sharp. I'd wait. Shouldn't be too much longer.
03CTDCO
Dec 14, 2004 04:53 PM
wils
Apr 29, 2004 07:40 PM
j
Mar 12, 2004 05:26 PM
Mr. 45
Jan 25, 2003 11:01 AM
Mr. 45
15
Jan 3, 2003 06:34 PM
