analog pyro & juice hooked into 1 tap?
Old Oct 28, 2005 | 02:18 PM
oxman's Avatar
can you run a analog pyro & the juices probe off of one tap? I like the juice but would like analog guages, don't want an empty tap/coupler/whatever you call it sticking out of the manifold if a warrenty issue came up
Old Oct 28, 2005 | 02:20 PM
RamWheelsBy4's Avatar
Some have posted it is possible, but I don't think it would work reliably. Edge recommends against it and I am sure any of the gauge manufacturers would not recommend it either.
Old Oct 28, 2005 | 06:56 PM
Dorkweed's Avatar
Muted User
From: "The Peoples Republic of Illinois".....behind enemy lines
Almost all pyro's work within a very specific/small millivolt range. I don't think either would work well with the voltage split between two different gauges!!
Old Oct 28, 2005 | 07:05 PM
tcr's Avatar
tcr
I have a banks sixgun speed loader and a autometer phantom series pyro both going to one sensor, works perfectly.
Old Oct 29, 2005 | 03:24 AM
DR3500's Avatar
the voltage is still the same if you y- the leads, that is how I have my TST hooked up. Just make sure they are parallel, not in series.
Old Nov 3, 2005 | 09:56 PM
Ramguy 05CTD's Avatar
Dr3500
Do you have a pic of your setup where the wires attach to the probe?
Old Nov 3, 2005 | 11:03 PM
dmanis's Avatar
I would make the excess wire short as possible to help eliminate any excess resistance that the gauge wasn't calibrated for. Why wouldn't it work? Voltage is always the same in a parallel circuit. If its off you would be able to tell, if you do some before and after tests.
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
CrashCade
Aug 27, 2008 12:54 PM
Hoss
Apr 11, 2006 11:37 PM
sandpuller2004
Mar 8, 2006 10:13 AM
