Airdog II Install question
to any of you who have installed the Airdog II how long did it take you to do the install???
Thanks, Adam |
Took me about 4 hrs taking my time and being meticulous. You can tally up another hour lifting the bed off (easier than dropping the tank). Its not too bad...
Originally Posted by rip 112
(Post 2542908)
Same here......
I spent a full day probably 8 hrs on it lifted the bed had to cut a factory bracket on the fram then the pump was hitting the bottom of the cab making noise so we had to pull the pump back off and modify the brackets. Plus I modified my canister to eliminate the 1/4 tank surge issue I can go for 30 miles with fuel light on.
The AD II is updated to resolve the 1/4 tank issues among other things, should be an easier install. Charlie and the boys listened to all of us and fixed it up right.
