Airdog canister mod question
Old Apr 30, 2010 | 10:39 PM
dodgecowboy04.5's Avatar
So a little over a year ago I put my airdog on and modified the canister, works great, love it, a little noisy sometimes but not too bad. Anyways, after i put everything back together my fuel guage no longer works. I don't know if I damaged the sensor or what but it reads empty all the time now. At first it wasnt that big of a deal but i'm getting tired of having to go off of milage and i would like to have the gauge working again. I have the old style in tank deal so is there any way i can fix it or am i just going to have to replace it?
I do however get a kick out of hauling people around and they see i'm on empty and tell me i need fuel. I just say nah she'll run forever on E lol.
Old May 8, 2010 | 01:54 AM
Fisherguy's Avatar
I'd drop the tank or lift the box or whatever you did to put it in, see if the canister is turned or something that would stop the float from moving. If it looks okay pull the canister out and put an ohm meter on the wires to the float, raise and lower it and see if the resistance changes, if it's okay the problem is somewhere else. Hopefully you can buy a new float separate from the canister.
Old May 8, 2010 | 06:00 PM
Ok I'll give that a try, hopefully this is the problem because I would really like to have my fuel gauge back.
Old May 19, 2010 | 05:34 PM
GASKICKER's Avatar
is this a common problem? Im putting my AD II in tonight and I really like having a working fuel gauge.
later that night edit: found out after dropping the tank that my lift pump is not in the tank
Old May 21, 2010 | 12:35 PM
tesla440's Avatar
The only problem that I had was that I didn't disconnect the batteries before hand. When I started the truck up the fuel guage was on "E" and wouldn't move. I check out everything electrical & was getting reading on the wire, but the gauge cluster wouldn't move. It took a few start stops before the computer reset itself and now the gauge is working fine.
Old May 22, 2010 | 11:14 AM
Ok sweet. Ive had quite a few start and stops since i installed it but I'll disconnect the batteries and try and reset the computer.
lastcall190
Apr 16, 2011 02:59 PM
Spooler
22
May 6, 2009 06:50 AM
justutt67
Jan 31, 2009 07:55 PM
Fisherguy
26
May 22, 2008 11:31 PM
Super Googan
Feb 5, 2008 06:29 PM
