AirDog 150 & tank vent mod install on a Megacab
so you wouldnt have to cut your tank for the airdog 100 because you can keep the stock tube? how many gph improvment is the ad100 over stock, and do you guys think it would actually support 550hp?
i wanted to try and get around the 600 hp range to run the et's i would like but it sounds like the ad100 would be a much easier install if you dont have to cut the tank. i wonder if i could get away w/ the ad100?
I like how you did this.. I also don't see the stock fuel heater being that big of a difference and the airdog has awesome filtration so the stock filter housing is useless if ya ask me.. So the airdog 150 bypasses the stock filter housing. I to am going to do the vulcan 1/2 draw straw and vent mod when I do my airdog 150 install also. That will flow enough fuel then right like you did? My question is I see you put a 90 elbow tapped to read your fp.. What kind of gauge are you using to read it? Is your gauge under the hood or did you run a line inside the cab?? Where does the 90 elbow hook up on the cp3 to read fp
im having problems w/ my electronic sender being installed in the tapped 90* vulcan fitting at the cp3. my fuel press gauge reads different almost everytime i drive the truck. sometimes it reads 13-14psi and other times it reads 18-19psi.
so far everyone has told me not to install the sender directly onto the engine because the vibration will cause it to be innacurate and also kill the sender quikly. everyone has suggested relocating the sender further down the fuel line w/ a tapped t-fitting. others have said to use a length of hose from the cp3 fitting to locate the sender farther away from the engine.
i ordered the tapped t-fitting from vulcan today and they gave it to my free of charge bacause the other tapped 90* fitting i got from them had bad threads in it and was tapped too wide causing the sender not to tighten down. i had to drill it out and weld another tapped nipple onto it just to be able to use it. it has ben nothing but problems so far.
I am getting very variable pressure reading with my airdog as well. Sometimes the needle is right on 18-19, and other the needle will build pressure up to 20 then drop off to 12-13 and build pressure to 20 and then drop to 12-13 and keep repeating this process. I move my pressure sensor from the cp3 fitting to a tapped "t" from vulcan and still the same problem.
Really so all the new airdog 150 kits come with the vulcan draw straw? I have a quad fp/rp gauge coming and that has a electronic sending unit right? I have never had a problem with filling my tank so I may not do the vent mod.. What about deleteing the stock filter housing all the way.. Anyway to keep check engine light from tripping yet?
It is a little bit like the the Vulcan straw......................simply it is a piece of 1/2" PVC with threads on one end.
the new airdogs and raptors come with a vulcan drawstrawII...it is the same one I bought for my install....the PVC bulkhead fittings they were using are done and gone.....
Does this mean they will supply updated parts for existing customers?
Thanks,
Tim
Thanks,
Tim
Thanks,
Tim
Thanks,
Tim
The only thing i don't like about the kit is the electrical wiring. They tell you to plug the Deutsch connector into the stock LP. But don't give you the plug on the harness.
Other than that and no tapped 90 elbow for a gauge it's a nice kit. I've helped install 2 in the Cave both 3rd gen trucks.
