air dog or air dog 2
Old Jun 15, 2009 | 02:01 PM
trailinone's Avatar
I'm getting ready to make some changes to my truck. I don't want to have to worry about fuel pressure so I thought I would start with a air dog. For an extra $100, I can get the air dog 2 and it is suposedly better and adjustable. Any of you already running it on a 03? If so are you happy with it?
Thanks,
Chris
Old Jun 15, 2009 | 04:58 PM
Stovetop535's Avatar
I dont think I would spend the extra 100 on the ad2. The only differences between them are the draw straw, which you can fab up on your own following write ups on here, and the other difference is in how the pump works. I do not remember exactly what the difference was, but with their lifetime warranty I would just pocket the extra hundred. Are you looking at the 100 or 150? and is your pump relocated to the tank?
Old Jun 15, 2009 | 08:10 PM
trailinone's Avatar
I haven't looked to see where the pump is. Is it not standard on all 03 models? Which is easier to work with, the in-tank pump or the out-of-tank pump? I'm looking at the 100. Don't think I will ever need the 150. I'm won't be racing or sled pulls or ever get on a dyno.
Chris
Old Jun 15, 2009 | 09:09 PM
The pump would be on the backside of the fuel filter canister unless the truck has been into the dealer and had it moved to the tank. The in tank or out of tank pump does not really make a difference if your interested in the 100. For the 100, you just hook up the airdog fuel line to the suction line already in place for your tank.
Old Jun 15, 2009 | 09:44 PM
trailinone's Avatar
Thanks for the clarification. I'm not too mechanically inclined, thank God for a good neighbor. I will owe him big when this upgrading process is complete.
Thanks,
Chris
Old Jun 15, 2009 | 09:50 PM
aborgardt's Avatar
You might as well get the 150, they are both the same price. It isn't going to hurt anything having the extra fuel available. I just bought a 150 and it came with the draw straw.
Im not sure if i am correct on this but i do believe that the pressure on the 100 and 150 can adjusted. I believe it is a spring replacement, but again, im not 100% sure on this.
Old Jun 16, 2009 | 06:44 AM
trailinone's Avatar
I was thinking this morning about getting the 150 instead. I don't see what it would hurt.
Chris
Old Jun 16, 2009 | 11:03 AM
Yes there is a separate spring you can change out to change the pressure. It goes in the "return to tank" fuel line on the pump. The 150 comes with a draw straw, but the draw straw it comes with is different on the airdog 2 than the airdog that is on sale through the dtr store right now.
Old Jun 16, 2009 | 12:16 PM
AkitaSumo's Avatar
Will this new setup be available through the DTR store?
Old Jun 16, 2009 | 12:19 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Already is http://www.dodge-diesel.org/aiiideflwreg.html
Old Jun 16, 2009 | 12:23 PM
rip 112's Avatar
Great info!!! trailinone I would do the AD100 if that's all you want, I have the 100 and it supports plenty for my truck, I know they're the same price but the 100 is made for a reason and sold for a reason. I see it as my limit for power until I'm ready for more.
Old Jun 16, 2009 | 08:33 PM
Fisherguy's Avatar
A guy on one of these forums was making over 700 HP with the AD100.
AD, where do you plumb the return when 'the suction tube is not required', are you drawing from the canister?
