-   3rd Gen High Performance and Accessories (5.9L Only) (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/)
-   -   Again... Code info please (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/again-code-info-please-99642/)
PThree Apr 14, 2006 03:29 PM
P0069 what does this code mean in detail. Someone posted earlier what it meant but didnt give much detail. Would like an explaination please. Thank you for the help
MikeyB Apr 14, 2006 04:41 PM
I can't any info on this code other than it's related to the MAP sensor.
Do you have a performance box plugged into the MAP?
MikeyB
68ss Apr 14, 2006 05:00 PM
DRIVEABILITY - DIESEL
Symptom:
P0069-BOOST KEY ON RATIONALITY
When Monitored and Set Condition:
When Monitored: While the key is on.
Set Condition: The boost pressure recorded at key on is not within a calibrated range
from the inlet air pressure sensor.
POSSIBLE CAUSES
OTHER DTC’S PRESENT
INLET AIR PRESSURE SENSOR
BOOST PRESSURE SENSOR
INTERMITTENT CONDITION
TEST ACTION APPLICABILITY
1 With the DRBIIIt, read DTCs.
Are any DTC’s present for Inlet air pressure or boost pressure?
All
Yes ! Repair other DTC’s first.
No ! Go To 2
2 Using the DRBIIIt, compare the inlet air pressure (barometric pressure) sensor
reading to the boost pressure sensor reading.
Are the pressure readings within 6 in hg of each other?
All
Yes ! Test Complete.
No ! Go To 3
3 Turn the ignition off.
Install Miller special tool #9022.
Ignition on, engine not running.
Use the DRBIIIt and compare boost pressure reading to the regulated air pressure
for tool #9022.
NOTE: The reading on the boost pressure sensor may be slightly lower than
the regulated pressure.
Does the boost pressure sensor reading increase with the regulated air pressure?
All
Yes ! Replace the Inlet Air Pressure sensor.
No ! Relace the Boost pressure sensor.
52
PThree Apr 14, 2006 10:39 PM
Finally a real answer. THANK YOU SO MUCH!!!
