Aftermarket turbo and Pacbrake
Old Jun 13, 2006 | 12:03 AM
dodgezilla04's Avatar
I am in need of an aftermarket turbo for towing that must work with my turbo mount pacbrake. unfortunately I already checked with edge on the jammer bb, and the answer was no. anyone have any luck with this? read in the march 06 diesel power that a 03 ram dually has a super phat shaft with the pacbrake.
Old Jun 13, 2006 | 12:45 AM
BlueDually's Avatar
All of the Industrial Injectiom turbos will,
Get a SPS 62-12cm housing for towing
Old Jun 13, 2006 | 02:05 PM
will the 62-12 grow with me? it would probably be fine now, but what after injectors and maybe a tst?
the main reason for a new turbo is to lower egt's when towing, and secondary for more power.
Old Jun 13, 2006 | 03:28 PM
BlueDually's Avatar
I think DTR member Agades has made 487 on a dyno with a 62/14, tst/ez stack, at 45 psi and 1500 on the pyro,
The 62/12 would be great for pulling with the tst, If I dont get the Arctic air twin setup, I will definetly get sps 62/12.
Do a search on 62/12 and 62/14, theres lots of opinions
Old Jun 13, 2006 | 03:40 PM
staarma's Avatar
I was wondering the same thing after I installed the Pac Brake on my truck. The air cylinder bracket is about a 1/4 inch from touching the housing on the stock turbo.
Thanks for the info.
Old Jun 13, 2006 | 09:01 PM
twest's Avatar
My Truck Has that configuration. You will have to Shave off about 1/8 deep 1/4 long off the Pac Cylinder Bracket,Otherwise it may touch the compressor Housing.
Old Jun 14, 2006 | 09:53 AM
staarma's Avatar
Thanks, I'm most likely going to go with the 62/14 and I can now keep my Pac brake.
Old Jun 14, 2006 | 11:21 PM
me too, but i may get injectors, exhaust manifold, and another box to stack with at the same time. then i may just get the better hairdryer.
Old Jun 15, 2006 | 12:48 AM
D.Wiggs's Avatar
I know that with my ATS setup, mod's to the PacBrake had to be made in order for everything to remain Kosher!
Old Jun 15, 2006 | 10:36 AM
staarma's Avatar
Do you know what they are doing? Is it mechanical to fit the turbo or is it plumbing so the wastegate doesn't open thereby losing any pressure built up by the brake? Just curious.
Old Jun 15, 2006 | 11:16 AM
BlueDually's Avatar
the wastegate opens on a reading from boost pressure only, not back pressure
RottnRam
Jul 4, 2013 12:14 AM
mrcowboy65
Jun 5, 2013 02:05 PM
MNorby
May 29, 2012 06:42 AM
kblranch
Dec 5, 2011 11:27 PM
Patriot2500
Jul 24, 2008 10:29 AM
