Adjusting Boost
I Have 2003 So with a five speed. Also a Edge EZ with the boost elbow. My question is is there a way to get the boost down to about 30 lbs or so. I can hit 25 without the elbow and 35 with it . I understand that any higher than 34-35 is getting beyond the stock turbos ability. I don't want to explode the turbo. I usually pull aroud 10,000 lbs with my trailer and three horses. Egts haven't been an issue although without the elbow they are considerably higher.:confused:
With the banks big head I'll see around 31-33, plus you can adjust the spring tension a little lower if you want. They are kindof expensive though. You may be able to drill your existing boost elbow just a hair, if you screw up they're on ebay all day long for $10-15. I got my big head for $160.
Thanks I'll Try that.
