Adjust Fass Pressure
I got a fass 150/150,it idles at 16PSI and I can bring it down to 9 PSI. How can i make it around 20+. (readings at the CP3)
pretty sure you can get a new spring or a shim pack from your FASS dealer to adjust the PSI:cool:
Just pull the spring from the return line and physically strech it. I'm making 20psi with mine
I thought a shim kit was needed. Was that a trial and error "stretch"?
i replaced my spring to get my psi up to 21. i installed the shim kit too- that just reduces the noise of the fass pump a little.
Where is the spring and where can I get a shim kit?
contact member-diesel dan. he'll set you up. shim kit and spring cost me 15.00
