Accuracy of trans temp in Edge Attitude?
Old Aug 25, 2006 | 10:28 AM
Mega3500's Avatar
Question Accuracy of trans temp in Edge Attitude for '06 rigs?
The Edge Attitude says it will monitor transmission temperature, at least on the '06 trucks. They do this by getting some reading from the PCM, not by using an external temp probe like the Quad Commander does. Does anyone have any idea how accurate the trans temp reading from the PCM is?
Old Aug 25, 2006 | 11:08 AM
dlg449's Avatar
I'm still trying to configure my Attitude to get the reading; I can't find that option.
Dave
Old Aug 25, 2006 | 11:23 AM
Mega3500's Avatar
page 29 and 30 in the instruction booklet pdf go over how to change the values.
http://www.edgeproducts.com/pdf/inst...structions.pdf
Are you sure you got the model for the '06's? Apparently the trans temp monitoring is specific to the '06 models.
Old Aug 25, 2006 | 11:37 AM
badcompany's Avatar
Just installed my yesterday. Does anyone know how backcourt the boost is on the attitude. I’m going up to 40+ psi.
Old Aug 25, 2006 | 11:57 PM
hotmod660's Avatar
sorry i don't have a answer for you, but i hope somebody has. my banks power pda has a temp gauge would like to now how it gets a reading.
Old Aug 26, 2006 | 09:25 AM
Mega3500's Avatar
Well, I talked to Edge's tech support and this is what they told me regarding the '06 trucks:
...on the 2006 Dodge that they actually installed a sensor in the transmission fluid that is like any sensor you would install. This is in turn sending a analog data signal to the PCM. When in the PCM it is there and we are able to pull that data out and display it in the actual temperature.
I knew the the '06's had a trans temp warning light, I just didn't know how the factory was monitoring the temp.
Lark
Feb 20, 2007 05:20 PM
4x4dually
Aug 21, 2006 09:22 AM
BTDodge4x4
Oct 13, 2005 10:34 PM
bkrukow
Aug 17, 2003 04:44 PM
