9.25 front, standard or reverse rotation?
And if it is standard, are any parts interchangable with the GM 9.25 IFS front or Dodge 9.25 half ton rear?
(probably stupid quesitons)
Thanx.
Thanx.
Yeah, all high pinions are reverse rotation. It basically means the same thing.
They are good axles except for the hub assemblies.
It has 33 spline axle shafts that are 1.4" diameter. The 925 designation refers to the 9.25" ring gear, which is smaller than the previously used Dana 60's 9.75" ring gear. The GAWR is 5,500 lbs.
LonCray
66
07-15-2004 08:27 PM
TON4FUN
06-15-2004 01:43 PM
