48RE temp numbers?
I just put a trans temp gauge in an 06 48RE. Normal driving on interstate it runs about 140 degrees. If he's in town and doing a lot of stop and go with moderate accel. it can go as high as 175. Are these normal? He hasn't pulled with it yet. I put a Geno's Acu Temp Adapter on the hot line going to the cooler and was just checking to see if it works correctly. Thanks.
Temps sound about normal to me.
That is normal to slightly below normal. Certainly not high or anything to be concerned with. Enjoy!
Thanks guys.
Come down to AZ, mine hits 220 in rush hour everyday.
Originally Posted by Rob C
(Post 1561226)
I'm pretty sure he probably does. I have mine mounted in the coolant line and it gets that hot in rush-hour traffic as well. Mine averages around 170°-185° on the interstate. Your's is gonna be significantly lower if it is mounted in the pan. I'm sure you know that though......
Originally Posted by jgiachino
(Post 1561451)
Wow, really? Where is the probe mounted?? I think i have mine in the pan and i see 180-185*....drove to flagstaff this past weekend and got stuck in a 2 hour accident backup when it was 105*....trans got to about 190* on my guage.....so i'm assuming you have yours mounted in the line??
Mine stays around 150-165 all the time with a very rare attempt at 180. My.02.
Is there a bigger than stock tranny cooler out there that can keep tranny temps alot cooler?
Well obviously that's pretty disconcerning....if i'm showing 190* and others (with the probe in the line) are showing 230-240*....i mean that's a 40-50* dfference...i suppose i should start worrying about trans temp when mine shows anything above 190*
If yours is in the pan.... that would be advisable IMO.
I have mine in the test port and with a heat gun I have measured the pan, lines and my probe. My gauge, probe and line all measured the same 180* while the pan(stock) measured 20* cooler. How accurate this is I don't know but it's close enough for me.
Mine's installed per Quadzilla spec's for the Commander.
It runs normal 145*-160* back and forth to work and around town. Towing, 160*-170*, and have seen it go as high as 220* on big climbs pulling 14K. |
(Post 1561905)
