400-500 rwhp, tell me what you think, can i get there?
1)XZT (pressure only)
2)Homemade or AFE air intake
3)Smarty Jr
4)5 inch turbo back
5)pusher or new fass pump
6)modified valve body
7)Gauges; egt, trans, boost.
What yall think? I'm looking for the most reliable way to make the power... Any better ways, should I just sell my new xzt?
I'll take less power don't want to break anything prematurely, want to keep this truck for awhile.
3)Smarty Jr
4)5 inch turbo back
I've sent mine in twice now. It's very reasonable to do so. A lot cheaper than selling what you have and buying new. You can upgrade the old ones. I've done it. Just give them a call, tell them what you want. Usually not much more than $100 unless you order new wiring.
3)Smarty Jr
4)5 inch turbo back
3)Smarty Jr
4)5 inch turbo back
You're going to want to upgrade your torque convertor, as well as the valve body. You also don't need the 5-inch exhaust, unless you want it. A regular Smarty will put you close.
Your gonna need more then just a chip unless it's gonna be a dyno queen.
fuel system (airdog, fass)
turbo (little 62)
plus your other suggestion as well as an ugraded tranny will get you there for an everyday 400-500 horse.
turbo (little 62)
if you get a edge juice attitude you can get hot unlock feature. its a extra 180 HP (440 ft lbs torque) over the stock 325 HP and 600 ftlbs torque. why would you only need a msarty when a edge juice could do it to?
325 Stock HP + 180 edge HP = 505 HP
600 stock ft lbs torque + 440 extra = 1140 ft lbs torque.
