4" downpipe to fit 03 turbo.
Old Mar 17, 2009 | 09:28 PM
C Schomer's Avatar
What vendor makes a 4" DP to fit directly on an 03 turbo - without the need for the elbow. I think i've read about one before but can't remember who. TIA! Craig
Old Mar 17, 2009 | 10:01 PM
lmills's Avatar
would you be ok with a stocker off of an 04.5or newer? Or are you looking for aftermarket
Old Mar 18, 2009 | 04:23 AM
Dodgezilla's Avatar
I had a Banks brand 4"DP on my old 03. You removed the elbow to install it. It used a gasket to seal to the turbo though which was a pain. My EGTs dropped about 100 degrees immediately when I put it on. Back then I paid a ridiculous $200 for it......
Old Mar 18, 2009 | 01:05 PM
rip 112's Avatar
MBRP sells one, that's what mine is... but I agree a stock 04.5 up DP would work just the same.
Old Mar 18, 2009 | 01:50 PM
JJPage's Avatar
Then he needs a 04.5 cast elbow also. I believe he is looking to eliminate the elbow.
Old Mar 18, 2009 | 02:52 PM
Striper's Avatar
I got one from Industrial Injection.
Old Mar 18, 2009 | 03:00 PM
C Schomer's Avatar
I built my 4" DP a couple yrs ago and cut a flange out of 3/16" flatstock to mate directly to the turbo and welded it to my 4" pipe. Now I put on an inline Pacbrake and my flange leaks. It was fine before - not enough back pressure to know it wasn't perfectly sealed. I'm trying to find a nice machined turbo flange and change it cuz a stock 325 elbow and DP might not fit up exactly the same down below. I can have a machinist friend make one if I have to - 4" sch 80 blackpipe would be good material to use. I sure miss not having a lathe at work! Craig
Old Mar 18, 2009 | 03:03 PM
rip 112's Avatar
I thought it would possibly work....
92smokin blacky
Jun 14, 2011 06:01 PM
97catintenn
Jul 12, 2009 05:33 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
dodgediesel
17
Jun 8, 2007 08:40 AM
RowJ
Nov 16, 2006 01:39 PM
