3rd rail pressure sensor in 6500 km???
What to do? i have quad rail gauge hooked up and edge juice attitude. im on my 3rd rail sensor in 6500 km. I took truck into dealer this last time to get oil leak fixed and they said it wont start again like last time it was in. i checked codes and im getting P0192 P0088 P0237 P0113. My rail sensor reads 3400 psi when i turn key forward without truck running so obviously its hooped. Do these rams use lots of rail sensors or is it my edge doing this?
Yeah, the only code I've ever gotten is P0192, and I run a Quad Xzillaraider with a Commander. Coincidence? Yeah, right... I never have a problem if the box is off, but if it's on and I pull a long hill, the truck will sometimes go into limp and pop the CEL. I now keep a code reader in the truck just for clearing the code and getting out of limp mode.
so is my sensor fried again or is it just because i logged the code that it wont start? do i need codes erased before truck will start or just pop in another $900 rail sensor?
all 3 since i hooked up quad rail gauge. before then no problem. so ya dont worry im ditching the rail portion of the gauge and just using the quad for Lift Pump pressure. ill leave that part of it but ill unplug the t harness going into my rail pressure sensor. sound ok?
