3rd Gen Boost Guage Instal
Old May 8, 2008 | 07:55 AM
freytes2004's Avatar
3rd Gen Boost Guage Instal can someone help me out I went to SMARTY for my 06 and guages and I can't figure where to hook up the boost guage . Correct me if I am wrong but does it go inline on the hose that runs to the turbo? Thats where I put it and my guage acts crazier than a sprayed roach it goes to 20 holds goes to zero and stays I let of the pedal and it goes to 10 accelarate and it goes to zero. Please help the guages are Auto Meter.
Old May 8, 2008 | 08:09 AM
05CTDN8's Avatar
No....you need to install a boost bolt on the manifold. do some searchin on boost bolt and it'll fix you right up!
Old May 8, 2008 | 08:22 AM
jrussell's Avatar
Go to www.DieselManor.com and look at their gauge install pics. They also sell the boost bolt for like $7.
Old May 8, 2008 | 10:01 AM
boost guage
I knew I could count on DTR members thanks guys
Old May 8, 2008 | 11:05 AM
Nsomniac05's Avatar
on that line you were actually readin the activity of the waistgate. so im guessing, when you stomp on it it spikes, and then as the rpms climb, the needle drops and settles on 0 and it proly wiggles and jumps all the time.
Old May 8, 2008 | 11:08 AM
Nsomniac05's Avatar
also its not hard to drill a hole in the stock intake manifold, and tap the hole i think its 1/8 NPT. or you can buy an aftermarket one that comes pretapped for such applications. just take the manifold off before you drill it to keep the shavins out of the head.
good luck.
Old Jul 18, 2008 | 07:24 AM
stroker101's Avatar
what "range" boost guage is recommended on these 5.9L Cummings? i'm a new owner of a Cummings so i'm not sure what type of boost pressure i'll see on this new rig.i mounted a 35psi guage on my 97' Ford and never got close to that. 26-28 most of the time. thanks for the help
Old Jul 18, 2008 | 07:28 AM
jrussell's Avatar
You need at least a 50-60psi gauge on your Cummins (no "g"! ).
Old Jul 18, 2008 | 09:03 AM
soulezoo's Avatar
DTR 1st Sergeant
He's right. Autometer is mostly 60psi and that is what you need. I prefer the mechanical over the electrical. I have used both. Then when you go to twins, you can simply hook the 60psi gauge to the primary turbo and get a 100psi gauge for total boost .
anonymous_1
13
Apr 30, 2020 04:29 PM
BRUISER
Feb 2, 2015 11:25 AM
1qckdodge
Mar 5, 2007 09:53 AM
chrismez
Oct 2, 2004 08:02 PM
SuperGewl
Jul 29, 2004 09:32 PM
