2wd lift... anyone but CST?
Is there anybody out there who makes a decent sized lift for the 03' 2wd 2500 other than CST?
Fabtech? or anyone know of somebody... for $1,100 I would swap in a Dana Solid Axle and convert the truck to 4wd/manual.
thanks, anybody have pics of lifted 3rd gen. 2wd's?
good luck at doing it for $1100 for the conversion. but fabtech does not make one. you can find 1/2t 2wd lifts all day long but not the 3/4t or bigger
I appreciate the info. I run a 4x4 fabshop so the swap would mostly just take time/patience. I think it'd be badass with a Dana 60 on leaf springs and 35"s with a NV4500 adapted to it.
I would rather buy somebody's kit and throw it on. thanks again.
what about transfer case, new brackets and mounts and all the other suspension and steering components?
CST is the only one I was able to find, and you would also need different wheels as they require a different backspacing than what the stock wheels have.
$1,100 might be a little low but it wouldn't cost much more with junkyard parts...
dana 60 front end, leaf spring suspension... all brackets/mods could be done in house... dshaft too, even most of the steering could be made out of DOM tubing.
time consuming and a 1st for me but I have no doubt that I could do it.
also- I have decided to get a body lift in addition to my 1.5" spacer... I CAN'T FIND the body lift kit for my truck except for $450... guess I'll be making that also, I just want to know WHY a body kit is more than $150? can anyone confirm something I don't see?
I am gonna look tomorrow and start fabbing one up in a week or so. I'll make a thread for it so it can help someone else down the road.
yea, they are rack and pinion. I don't want to convert it to 4x4. I have done homework now and a body lift is more work than it's worth IMO.
I'll just put my spacer on it and some H2's (if I can find some chrome ones) and then add a spindle lift if needed...
when the truck gets a little older it MIGHT get tubed out and chopped up
hell, it's paid for, why not
rsscoggins
14
Mar 30, 2012 06:59 PM
deere nut
Jun 9, 2008 09:31 AM
