2006 blown freeze plug!
Got my truck back friday and I blew the freeze plug with in 20 minutes. Why woud this happen. The truck felt like it was running good. no bully dog downloader just edge going on 5 not hot juice. I cant figure out why the plug would come out? Foud a cool way to fix though.
when are you going to dyno it?
Originally Posted by BlackBeast
(Post 1287652)
Theres a way to fix it the real way....but its too complicated for me[laugh] |
Yeah there going to use the plate. My main question is what would cause your freeze plug to blow. is my truck set up wrong? It sure felt strong with only the edge juice on 5. I cant believe I had that much power with only the tuner it was insane. I hope some people out there can give me some good answers so I can figure out whats going on. There fixing it on monday tomorrow. Thanks Guys. p.s my buddy would not give my larry back so I sold it and bought a PPE. Keep in mind my motor is a new long block.
when you gonna put it on the rollers?
what plug did you blow?
Dang dude that sucks!!!!![verymad]
was your truck up to operating temp yet??? |
Why exactly does a freeze plug let go? Do you loose all coolant when it does pop?
Originally Posted by Nate-03 D
(Post 1287824)
Would a blown head gasket cause a freeze plug to blow??? Does your truck just have headstuds?? how much boost where you running?? Yes most all of the coolant would spew out of the engine. |
Originally Posted by 53 willys
(Post 1287834)
they can go because they get old and rusty, but that would not be the case here. (It might have been installed wrong or not seated all the way too.) Would a blown head gasket cause a freeze plug to blow???
Yes most all of the coolant would spew out of the engine. coolant coated the underside of the truck....the temp gauge was maxxed....and the engine idled up to 1100. |
i popped mine at the track. shut the track down for an hour. no iea why it popped.
Originally Posted by judge88
(Post 1287868)
Where can I locate my freeze plug? I would hate to be under WOT and have mine pop open. How can you re-enforce them to prevent them from popin?
Has anyone ruined an engine from this happening? |
the twice I have seen it happen it was with a Smarty/TST stack. cylinder pressure was too high i guess....but occured on 04.5 trucks that I know of....but it happens on other models too. |
I blew the plug getting on the freeway. We were just doing a test run just got everything put on the new long block. I want to know why this happened i was not even stacking. My truck blew up a few months ago and I just rebuilt it so i want it to work right. I dont think the boost was that high it couldnt have been I only was running the edge on 5. I need more info on why this would happen. Pl
