2005 6sp edge ez,juice and attitude here on monday
Old Oct 22, 2005 | 09:05 PM
mikcon's Avatar
I have the goods showing up on monday.
I hope I like this set up if not keep looking it will be for sale.
Any suggestion on install? and settings?
I know the juice should be adjustable in cab is the ez and if so what do you guy think is a good starting place.
Some are saying put the ez on 1 and leave it use the juice for everything else.
If I put it up higher is the pressure always higher or only when you get in it?
Any info is great.
Seemed like the right time the truck is 28 days old and has 1300 miles so it is not new anymore time to play.
thanks
Mike
Old Oct 22, 2005 | 11:23 PM
ftltmp's Avatar
I don't know anything about the ez, I have the edge juice w/attitude and I love it. I do 99% of my driving on lvl1 and when another dodge or a ford tries to be funny i will reach over and bump it up to maybe lvl3 sometimes lvl5 . You will notice a difference on all settings.I like the fact that you can set saftey margins to keep from damaging your eng.Install is pretty straight forward just be careful when you tap your manifold for the pyro. I am sure you will enjoy it.
Old Oct 22, 2005 | 11:35 PM
drew03's Avatar
i have been running my ez on level 1, it is a pain to adjust if you ask me. i am going to turn it back up to compliment my straight pipe.
Old Oct 23, 2005 | 07:11 AM
mikcon's Avatar
I thought the ez also had a in cab adjustment?
Old Oct 23, 2005 | 07:26 AM
mikmaze's Avatar
the newer ones do, in cab 3 clicks/ levels I am still deciding if I like my quad box before I put the ez up for sale tho
Old Oct 23, 2005 | 11:59 PM
drew03's Avatar
when you say the newer ones are you talking about newer year model trucks or the new boxes??
Old Oct 24, 2005 | 12:29 PM
staarma's Avatar
I have the juice/aatitude with the ez stacked. I leave my ez on level 1 and then the juice anywhere I need it. The ez has a 3 position switch that I mounted on my attitude pod. If I use the ez on anything other than level 1 it runs out of fuel and hesitates around 2750 like someone turing the key off and then it comes back to life. I'm still running the stock lift pump.
Both install very easy. The only time consuming part is the thermo couple install. Have fun.
Old Oct 24, 2005 | 12:46 PM
RamWheelsBy4's Avatar
I agree with staarma, without air intake and exhaust at least you dont really need to stack an EZ with the Juice/Attitude. Level 1 may give you a little low end help, but without all the other mods you wont really be able to use it efficiently. I stacked an EZ with my HOT Juice/Attitude and all of the mods in my sig. Without the FASS I ran out of LP pressure pretty quick.
Old Oct 24, 2005 | 05:09 PM
mikmaze's Avatar
I was talking about the new model ez for the newer trucks, havent seen any for older ones with in cab clickers, then again why would I look? theres enough toys for my truck I don't need to confuse myself with options on other trucks
Old Oct 24, 2005 | 06:51 PM
I made my statements about 04.5 600 with standard Juice/Attitude. There was no way that the new adjustable in Cab EZ would have been any real benefit until other upgrades. Just trying to give my real world experience.
UNBREAKABLE
3rd Gen All Products
Feb 18, 2015 12:55 PM
tvanry
Jun 9, 2008 02:25 PM
tvanry
May 29, 2008 09:17 PM
treadway47025
Nov 15, 2006 05:43 PM
razor6
22
Jan 20, 2006 03:43 PM
