2003 * Bulldog chip, good or ?
Bulldog power chip , good or bad ? for 03 Dodge high out put . better fuel mileage , ? Also a breather that has no restriction at max RPM . Thanks
Re:2003 * Bulldog chip, good or ?
Jim, I have one and like it. Comes on fairly low but hits kinda fast/hard all of a sudden around 1800-2100 RPM. It defuels at higher RPM about the same profile as stock so no, it doesn't breathe huge at high RPM. But some of that limitation is my turbo.
I dynoed with stock injectors, stock air filter and 4" exhaust and did around 400hp with it in High. Vaughn |
just wait for the newer boxes expected to come out at the end of november....
p.s. expected to add over 160 hp :o |
Check this link
http://www.dodge-diesel.org/yabbse/i...threadid=21502 |
End of November :o :o
I have a big tip planned with my 10K ; 5`er at the end of November. I need a box before then or it will be a long 900 miles :-[ |
The Bullydog I have trips the engine light a few times, gives an intermittant stumble in acceleration with no pattern and sometimes it seems like when I let off the throttle it pauses for a second before the rpm drops.
It does have nice power and I know of a few other folks with the same experience as mine. I am in contact with the folks to see what can be done to resolve this. [eyecrazy] |
Bulldog chip, or Bullydog chip, are thay the same ? The Bulldog chip, is sold by Performance Products .
