2" levelling kit -- Need aftermarket shocks?
Old Apr 18, 2008 | 06:51 AM
Moobesor's Avatar
I am about to install a 2" levelling kit. The company states I don't need anything else to make everything work right.
Has anyone installed these kits without aftermarket shocks? I won't be doing much off-roading, but if I did what may happen?
The kit is just the block you mount about the coil spring.
Old Apr 18, 2008 | 08:23 AM
dwiningernm's Avatar
I put a 2 inch level on my truck and while you may not "need" shocks, they will run out of travel real fast if you keep the original ones. I went ahead and put new ones on with my kit. I personally would suggest new ones just to make sure. I've added a rear leaf (about 1.5" lift) and while I didn't go longer shocks there I will when I replace the ones that are currently in use.
To me, shocks are pretty cheap in the big scheme of things and worth the money to keep them in good shape and of the proper fit. Especially when you consider they are helping keep those expensive tires in better shape and lasting longer.
Old Apr 18, 2008 | 08:47 AM
donnee's Avatar
I got a good price on shocks from here.
http://www.shockwarehouse.com
Plus free shipping.
Old Apr 18, 2008 | 08:59 AM
t-boe's Avatar
I've been running one for the last 1000 miles with stock shocks. Normal driving situations (speed bumps, dips, Geo's) don't require new shocks. If you plan on taking offroad a bit then shocks are a good idea.
Old Apr 18, 2008 | 09:40 AM
gscmiller's Avatar
Ive been running a 2" level kit w/ stock shock for about 25K> seems to be ok. If i were to do it again, I would replace stock shock all the way around.
Old Apr 18, 2008 | 05:59 PM
tristan21's Avatar
Thuren can hook you up if you ever need the Premiumshock capabilities.
sallyman1
16
Apr 21, 2009 04:47 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
bogie418
Feb 16, 2007 12:14 PM
triplenickel
18
Aug 5, 2006 09:55 PM
triplenickel
Aug 23, 2005 04:19 PM
