1/4 mile times with tst on 600
Old Oct 3, 2004 | 09:25 PM
lightening ram's Avatar
ran me truck this weekend at the track and was kind of dissappointed, thought it would be a little better, on 5/5 did 15.2 and 90 mph, 6/6 15.1 92mph, 7/6 really pushing it ha ha 15.0 93 mph, any one else have any experience with these times also? 60' times were 2.23 to 2.26 .
push it till it glows
04.5 3500 srw flow master 30 series race muffler no cat {sweet sound} 285 bfgs, k&n cold air intake, trans temp in srt pillar, 48re trans, 4.10 gears, mopar tonneau cover, 2" lift, 1 ton dually springs rear, mopar oval boards, srt hood, silver, chrome handles, painter ventvisers and rear window deflector,tinted windows.
Old Oct 4, 2004 | 02:45 AM
DRV's Avatar
DRV
That is pretty good, with my Dr performance got 15.47 in my G tech. good until the box when south, looking into new module. How happy are you with TST. Any engine light on ?
Old Oct 4, 2004 | 08:11 AM
RamWheelsBy4's Avatar
I ran 15.65 with Dr Performance Stage II (85hp/160fpt). This is with 315s, 3.73 gear, auto and stock exhaust.
This is not very good, except that it is 1.2 seconds better than without it.
DRV, how did your Dr Performance box act when it went bad? Mine is idling rough at startup and doesnt seem to like the new Banks Exhaust that is installed. No improvement with the exhaust.
Old Oct 4, 2004 | 06:11 PM
Ttexas25's Avatar
What were you egt's on the runs you made?
Old Oct 16, 2004 | 12:17 AM
way toooooo hot texas 1500 plus pre turbo, had to move my defueling number higher ha ha after all its in seconds right?
Old Oct 16, 2004 | 04:47 AM
DRV's Avatar
DRV
Ramwheels.
Dr Performance was maybe the best I have tried. Started acting up, by truck loosing power until one day did not start. I was still in my 30 days trial and it was change for a TST.
Old Oct 16, 2004 | 01:18 PM
ttreibel's Avatar
The fastest 3rd Gens I have seen have Twins, TST, and stage 2's and they are running the mid 14's sounds like you guys need more air not fuel to break out of the 15's........BTW both the trucks with twins up here are still running stock 48RE's with 500+ HP on the Dyno
Old Oct 16, 2004 | 10:51 PM
DRV,
Thanks for reply. I took my Dr Performance II off to have the TSB 18-037-04 done. Had it off for about 10 days now, miss the extra power. I dont know if I trust the box anymore. My mileage was dropping very quick just before I took it off. Was running kinda ragged at startup and low rpms.
Past my 30 days, so may try to get new unit from dealer.
Old Oct 17, 2004 | 07:14 AM
Dave04600's Avatar
Were you leaving the line under boost?
Old Oct 17, 2004 | 10:21 AM
Dave04600
When the truck was stock, did one run powered braked the boost to about 18-20 psi. This produced at very good launch. 60' time completely stock with 315s, half tank of fuel, was 2.38. But the guys with more knowledge than me said that was too hard on the stock drive train(trans, input shaft,etc.).
I have backed off to power braked boost between 5-10psi. I am still trying to decide what I am going to do with the truck. I want to be in the 13s, just dont have the money right now. So for now I will try to drive my age instead of how I want.
Old Oct 17, 2004 | 01:37 PM
StrokeThisCTD's Avatar
so is the TST box set on 7/6 ok For daily driving, or should it only be done on the track? I was going to buy an Edge for the new truck since its limited to 220tq, and i know the trans/tc can handle that.
if i get a TST, can i set it on 7/6 and not have to worry about something exploding?
Old Oct 18, 2004 | 04:46 AM
x_ram-on_x's Avatar
I 2nd Strokes question
My 2005 3.73 48re will be arriving within the month and I'm itching to install the TST module. However, I'm not sure how high a setting is safe for the stock trans. etc....
Just how high can you push hp/torque before having to upgrade components?
Old Oct 18, 2004 | 06:50 AM
Don-T's Avatar
My TST set on 5/5 is more than enough to get the torque converter to slip/chatter. When it chatters like a bad clutch the whole truck shakes. I can't run any higher than 4/3 until I can get a new transmission.
Old Oct 18, 2004 | 11:21 PM
ramtd02's Avatar
does the tc slip or chatter due too torque?? Because the 48re is being used in the 2005 SRT-10...which is 500/525 at the crank mind you.
Old Oct 19, 2004 | 06:50 AM
Lsufan78's Avatar
yes, BUT the tc in the srt vs. the one in our rigs are definitely not one in the same!! way different powerbands.
later, dustin
