06 Lift Kit
06 Lift Kit RAM 3500
Anyone use a lift kit from top gun customz from ebay,good-bad?How's the quality?Is there a better lift kit with out spending a ton of money?
Thanks for the help.
8" 03-07 Dodge Ram 2500/3500 4x4 Long Arm Lift Kit
Item number: 230165920468 This kit runs about 2 grand with shipping.
I'm looking to fit 37-40 tires would love to get the kelderman air lift kit, but about 10 grand stands in my way.
Ry,
There are a couple of ways you could work it. Rock krawler has an 8 inch kit,
topgun customz has an 8 in kit that they sell now. You could also take any 6 inch kit and add a 2 in spacer with a little bigger of a block in the rear and you are good to go. I am waiting for rize to come out with their 8 in kit. Just keep looking eventually the manufactures will realize that we are out here and ready to buy!!!! My .02.
I went with the 6" lift from top gun with the rock krawler upgrade long arm and track bar, top gun dual shock mounts. I really like it and it rides about the same as factory. The only thing is once you go with the long arm conversion there is no going back to factory. I also put an additional steering stabilizer. This is the site i got it from. http://www.solidsteel.ca/Products.htm. I think you'll be happy with it.
Please check out KORE or Carli Suspension. These 2 are the only suspension systems I would install on a Dodge Ram. If you have the choice of such high quality components why not do it right the first time?
no i believe there suspension only add 2.5" to 3" of lift but the engineering is what sets them apart from the rest. check out
www.prozac.la
www.prozac.la
Topgun makes a 6" and 8" that you can upgrade with Rock Krawler. http://www.topguncustomz.com/Store/products.php?S_ID=51
I've got installed on my truck and works and rides well. No problems so far.
