06 boost gauge
Old Jul 5, 2006 | 08:51 PM
2500TurboDodge's Avatar
06 boost gauge
were do i tap in for my boost gauge on my 06 2500 and what am i goign to need
Thanks
Danny
Old Jul 6, 2006 | 01:00 AM
BlueDually's Avatar
do a search on a "boost bolt,"
or if you plan on usong the tst you must tap a hole in the intake horn, cant remember what size,
Old Jul 7, 2006 | 08:55 AM
UnrulyNFS's Avatar
I got the R49 TST and didn't have to touch anything for boost monitoring. I think its done electronically. No boost bolt.
To hook up the exhaust gas monitor, I just tied into the one I already installed for my gauges. But, there was nothing to hook up as far as a boost bolt on my '06.
Old Jul 7, 2006 | 12:20 PM
Boz007's Avatar
What kind of boost are you reading? I was under the impression that the box's with gauges dont accurately read boost. I used a boost bolt for my mechanical gauges and i hit as high as 40psi with just the Quad XZT.
Old Jul 7, 2006 | 01:13 PM
AggieJustin's Avatar
Boxes with gauges will read the boost directly off the MAP sensor, prior to sending the clipped signal over to the ECM.
If you use a scanner to look at boost seen by the ECM, you'll get incorrect readings on a truck with a box when it's doing its "boost fooling" function.
gpshemi
3rd Gen All Products
0
Jul 19, 2015 06:25 PM
Tank_66
Feb 28, 2008 08:34 PM
turbomike
Dec 3, 2007 09:31 PM
MoparMarv
May 4, 2006 04:41 PM
CRXsi
Mar 31, 2006 07:56 AM
