05 Edge Juice w/Attitude?
Old Nov 28, 2007 | 04:45 PM
Rock Hauler's Avatar
Question 05 Edge Juice w/Attitude?
I just installed a used Edge Juice w/Attitude on my 05 3500, I didn't get the installation instructions,so I downloaded it from Edge's website and it shows 3 wires (2 yellow,1 red) that hook up to the fuse box, but mine only has 1 red wire and 1 ground. What fuse should the red wire connect to. I hooked it up to fuse #26 according to the website, Does the Attitude moniter suppose to go off with the ignition, mine stays on when I shut the truck off.
George
Old Nov 28, 2007 | 04:52 PM
skynyrd's Avatar
yes the monitor should go off with the key in the off position. you need to choose another fuse to attach the edge power to. look at the lid of the fuse box and find the fuse for the cig lighter and use that fuse it goes off with the ignition.
Old Nov 28, 2007 | 05:20 PM
Hey thanks thats what I needed to know. Does anyone know if you can get the turbo timer added to the Attitude moniter for an 05.
George
Old Nov 28, 2007 | 06:04 PM
djbikeman's Avatar
I still have my instructions from my Juice/Att that I had on my 04.5. It should be the same unit you have.
It says to tap fuse #50.
On my 06, the turbo timer plugged in under the steering column from the Juice box, not the Attitude monitor. I don't think you can upgrade it without getting a new Juice module.
Old Nov 28, 2007 | 06:08 PM
chevota01's Avatar
The 05 juice does have a turbo timer option. Call up edge. It can work via EGT setting or timer -- works great.
5.0 Mustang Man
Oct 21, 2008 02:50 PM
razor6
22
Jan 20, 2006 03:43 PM
PThree
22
Feb 14, 2005 11:11 AM
john@dps
19
Dec 30, 2004 07:10 PM
Big Bob
Dec 24, 2004 04:10 PM
