03 ECM defueling
Old Oct 27, 2008 | 11:53 AM
masonic-dodge's Avatar
03 ECM defueling
Who has had a 03 ECM that defuels at about 44psi? If you have what did you do to solve the problem?
Old Oct 27, 2008 | 12:46 PM
JOESHTRDDSL's Avatar
Mine will defuel hard when trying to do a boosted launch. To fix the overboost defuel I use a Quad boost fooler. To fix the boosted launch defuel I was told between turning off the shift defuel on the Smarty and running a Dr. P box should take care of that. That is what I was told but I have not had a chance to get to the track since the changes I've made. Joe
Old Oct 27, 2008 | 05:03 PM
DUKCALN's Avatar
Boost fooler and the shift defuel. Buddy had the same issue. Smarty will only fool to 44psi, after that a fooler is needed.
Old Oct 27, 2008 | 06:17 PM
What about the TST box, my other truck went to 70 PSI. I think I need a ECM
Old Oct 27, 2008 | 06:38 PM
DENVERDODGE04's Avatar
not to rob a post here but did the early 04's use the same ECM?
Old Oct 27, 2008 | 06:47 PM
No the 04s are different.
Old Oct 28, 2008 | 05:52 PM
I've been offered a boost fooler from a great friend on here Jess sprull. I think I'm going to take him up on his offer to see if it solves my problems.
Thanks Jess
Old Oct 28, 2008 | 06:10 PM
BossHogg's Avatar
So even though my smarty has a boost fooler I still may need one...say from Quad or somebody like that?
My 04 seems to be getting to 44psi, and I guess this may be a reason why. Never heard of this before though.
Old Oct 28, 2008 | 07:56 PM
Jess is sending me a boost fooler to try, I hope to see the truck make the mid 800s where it should be
Thanks Jess
ratat98
Sep 18, 2016 07:34 PM
6spd05Dually
Mar 12, 2011 12:19 PM
jrussell
17
Sep 17, 2007 06:38 PM
Ohio Joe
Jul 12, 2004 12:13 PM
