Who changes their own oil?
I use an oil filter cap wrench on a long extension from under the truck to loosen the filter. Once the filter is loose, slip a plastic bag over it from the bottom and spin it off. Make sure you use a large open drain pan(yellow 15qt-walmart) and not the type with just a hole in the middle. Drain plug torque is 37ftlbs.
You can also get them at Harbor freight... a whole set for less than $10.
I changed my oil in my truck myself this last time around. First time I have changed my own oil in probably 10 years. Glad I did... it was easy. No measuring to do if you change the filter. Just pour in 3 gallons and check it.
For those questioning why I didn't do it sooner... I owned a Chevy and a dealer in my area offered oil changes for $12.95 on Tuesdays (gasser). Why wouldn't you have them do it at that point... they checked fluids and lubed the chassis too! Miss that.
Oil changes on these trucks are so easy everyone should do them. The oil comes out quickly so make sure you have a pan or container that can keep up. I use an empty kitty litter bucket. I reach through the wheel well and loosen the filter by hand but remove it from underneath. Reverse the process to reinstall.
And I replaced my drain plug with an EZ Drain from Geno's:
I use a 5 gallon diesel jug as a used oil holder for my truck and power equipment. It has "USED OIL" written in big letters on it so there are no mix-ups. When it gets full, I dump it out at the local recycle center on the way to town.
I would like to visit this Geno's site. www.genos.com got me to a place that wanted to treat me for depression. I just want to learn more about this oil pan plug and drain. Would appriecate a web address. Thanks in advance.
