Synthetic Oil
I can sleep now, my Smarty is safe.
Synthetic Oil
I have 116K on my 6.7. I am thinking about going to synthetic oil. Good choice or will I be better off sticking to dino or a blend?
In fact Cummins ships the engine from the factory with 5W-40 synthetic oil. This was stated to me on a factory tour in June 2013.
Jim W.
I change my oil and filter every 6 to 8 thous, miles twice a year so I went back to the dino oil, both the synthetic and dino oil I use were Rotella. I really didnt notice any differance, cheer`s
It wont hurt the engine. It (synthetic) costs more so if you are going to run extended OCI then it will be worth it. As long as it is a proper spec'd oil you will be fine, be it dino or synthetic oil. I personally just went the opposite way, I ran Mobil 1 5w40 for 6 of the 7 years I've had the truck, and just put in Mobil Delvac 15w40. You will be fine with either. Best to you.
Thanks for the replys. I usually run 3 to 4 thousand OCI because I don't put alot of miles on. I use this truck to pull my fifth wheel but it is also my daily driver. I like the idea of the better oil for the grunt work but it seems a waste for the daily driver part.
With those kind of miles, price-wise you would be better off sticking with Dino oil. Valvoline, Mobil, DELO, Rotella, Heck even good service from Supertech oil from Wal-Mart has been had, your choice. Oil choices on the forums are a heated debate as to which one is best, But all have come back with good results from oil samples. As a better price point you might want to go out to between 5000-7500 miles on your OCI's. If you wanted the Syns then anyone of the above mentioned brands will serve you well also (Except for Supertech). Best to you.
Roadstar
01-14-2010 03:50 PM
Roadstar
01-11-2010 06:44 PM
rico334
01-03-2005 08:10 AM
snice
14
04-29-2003 08:41 PM
