Shudder when braking
This has happened a couple times (~5 times over a couple months). Running 55-60 on cruise with exhaust brake on. I'll get on the brakes and the truck will judder like when you bring a manual to a stop in gear without using the clutch. Truck normally brakes just fine so I'm thinking it's transmission related. I did the trans filter and partial fluid change at 150K when I adjusted the valves. 6.7 Cummins, 68rfe, 4x4, 180K miles (owned since 143K) on it. I don't tow real heavy with it (~8K lbs once or twice a month for 400 miles). I have the Smarty set on the performance tune and have it dialed down to 80% power just for the timing and trans tuning without the smoke. Anyone have any ideas?
Originally Posted by Angrywasp
(Post 3375664)
| All times are GMT -5. The time now is 09:47 AM. |
