"performs service" on overhead on 2007
The manual says it is either ccv filter, cleaning or replacemt of Egr cooler, or clean or replace Egr valve. How do you know which one it is?? Would the delete take care of all that? Thanks for any info.
Just a cleaning of EGR and cooler, replace crankcase breather filter. Key on then Step on brake twice then gas pedal twice key off will reset minder. If you have deleted then just replace breather filter.
K. I am test driving this truck, so I just wanted to make sure that is no big deal. Needs a front pinion seal and front crank seal. Gonna have dealer fix those to close deal. Now I guess clean the Egr stuff is now added!!!
The perform service message comes on at 67,500 miles.
