Passenger Headlight Bright Will Not Work
I had a headlight bulb go out recently so I replaced both headlight bulbs. Passenger bright side went out so I bought another bulb. After putting it in I discovered the dim side works fine but bright will not come on. The driver side dim/bright work fine. I put a multi meter on the plug and I'm showing power to both poles. Anyone have this happen or ideas what it could be?
it will be necessary to use a sharp probe to do this, but check for full voltage right behind the bulb socket. My experience is that sometimes the contacts inside the socket does not make contact with the bulb. If you are careful it may be possible to reach inside the socket and check for voltage on the contact itself.
Let us know what fixed the problem.
I have yet to fix mine but got a reply on my original thread that replacing the TIPM fixed one guys problems. He ordered from MAKS using his VIN once installed all problems gone. said it cost around $650
efil4ynot
Jan 11, 2010 09:35 AM
hyunsinsone
44
Jan 21, 2007 01:10 PM
CTD NUT
19
Apr 15, 2005 05:58 AM
