P0472 code after smarty install
Old Mar 3, 2020 | 07:44 PM
justin5's Avatar
Hi everyone! I have a quick question I have a smarty jr running the 28 me version once I purchased it I threw it on my truck and once I flashed it to the tune I wanted i got a code p0472 the code was on there with the previous tune but once I flashed it with the smart y’all of a sudden I got this code..any ideas?
Old Mar 4, 2020 | 12:08 PM
mega-engr's Avatar
"California Style"
Make sure that module for pressure is plugged in and wasn't electrically disconnect somehow previously. Also check this out:
Old Mar 4, 2020 | 04:30 PM
justin5's Avatar
https://www.youtube.com/watch?v=glxzuH2lEyc
thank you for the vid I ordered a new sensor for it anyways but I will clean it out it won’t have anything to do with the tuner right? Cause once I loaded it up it threw that code but I’m wondering if the tune that was on the truck was just blocking it out..
Old Mar 4, 2020 | 04:52 PM
mega-engr's Avatar
"California Style"
You said the code was on there with the previous tune? Or did you mean it wasn't on there?
Old Mar 4, 2020 | 05:05 PM
mega-engr's Avatar
"California Style"
Yes, the new sensor will be useless even if that port is clogged with soot. The downfall of most of the system on this motor (soot and emissions).
Old Mar 4, 2020 | 05:09 PM
justin5's Avatar
to reply to you’re top comment no it wasn’t on there until I flashed it with the smarty..and I know the smarty has the right “me” software because it has 28 me when I plug it in so I was wondering maybe the old tune was just blocking that CEL from coming on..and the sensor is actually bad as well as being clogged up? I just found it odd that once I tuned it with the smarty the light came on
Old Mar 4, 2020 | 05:16 PM
justin5's Avatar
confusing but to shortened it up the cel didn’t come on till I flashed the truck with my smarty
Old Mar 5, 2020 | 12:41 PM
mega-engr's Avatar
"California Style"
Do you know what tune you had in there before? I assume you have things on the motor and emissions deleted from such previously? Perhaps it was coded out in the previous tune? Or just coincidence that it got clogged and bad about the same time as new tune with the smarty.
Old Mar 5, 2020 | 01:02 PM
justin5's Avatar
that was the thing I don’t know which tune was on it that’s why I bought the smarty I have a feeling it already went out before I put the smarty on and that other tuner coded it out..
Old Mar 5, 2020 | 02:04 PM
mega-engr's Avatar
"California Style"
I think the good news is that it shouldn't be too bad to fix. You have a new sensor so that is great. Just make sure that housing it resides in is clean/clear and that sensor tube that feeds this is clear. Is this the only code/issue you have?
Old Mar 5, 2020 | 03:05 PM
justin5's Avatar
yes sir that’s correct it’s the only code that’s present on my truck..doesn’t let me clear it nothing just stays constant so I have a feeling it’s just the sensor good news is it comes in Saturday.
Old Mar 8, 2020 | 11:12 PM
justin5's Avatar
U
update! Today I got around to installing the new sensor so far so good the old one wouldn’t even let me clear it as soon as I plugged this one in the pending code went away I cleared it and it has came back! Fingers crossed..thank you for you’re help
Old Mar 9, 2020 | 11:24 AM
mega-engr's Avatar
"California Style"
Excellent! Hope the code stays away now then with the root cause being the sensor. Curious what it looked like where it connected to the exhaust port housing.
pwr2tow
Apr 29, 2009 05:48 PM
JOECUMNS
Jan 22, 2008 09:10 PM
dansdodgediesel
Dec 1, 2007 08:56 AM
DrBoost
Oct 21, 2007 12:51 AM
