P-242f-Diesel Particulate Filter Restriction-Ash Accumulation
Old Jul 30, 2009 | 07:08 PM
claydawgs85's Avatar
i just had my DPF clean itself again for the second or thrid time this month. i did every thing i know to do. I drove around for awhile and the DPF reg. process was done but i had a check engine light come on. came home and turn the key three times and got this code to come up( p 242F and aslo a p 1451) What does this mean. will i need to have my DPF replaced. If i do i am going to just get rid of the dang thing( the filter not the truck). Any help will be great thanks.
Old Aug 2, 2009 | 02:36 PM
djdc's Avatar
Had the same problem. Had to replace my DPF, (under warranty). How many miles on the truck.
Old Aug 2, 2009 | 03:10 PM
bob4x4's Avatar
Is that with a chip as in your sig?
Old Aug 2, 2009 | 04:05 PM
i have a little over 23,000 miles onthe truck now. No i dont have a chip on the truck yet i was going to get one but some stuff fell threw for me. i took the truck to the dealership and i wont know anything on it until hopefully monday. I will let you guys know some thing as soon as i do.
Old Aug 3, 2009 | 06:46 PM
Just talked to the dealer today. I'm getting a new dpf and they are cleaning the turbo. But they say I need a new crankcase filter.
Old Aug 3, 2009 | 09:49 PM
sdguy55's Avatar
I hate DPF filters, such a waste. If ever i get my new TDI (crossfingers) and it doesnt have to run on emission stuff (cross all fingers and toes) then im rippin it all off and putting a brand new 3" straight pipe on that badboy.
Old Aug 3, 2009 | 09:58 PM
tnhtractors's Avatar
I have 86473. miles on my 08 and never had an issue with my dpf , as for crank case filter I replaced mine myself ( located right underneath valve cover, just remove valve cover bolts and lift it off, its huge same size as the inside of valve cover) owners manual tells you how many miles you go before changing it, you will get a cel light and a message to see dealer. maybe yours got clogged up and its messing with air movement in motor.
jimmyd
Mar 29, 2009 05:36 AM
tomd
Aug 28, 2008 02:21 PM
eb290
Jul 21, 2008 06:07 PM
Steven C
Mar 16, 2007 09:05 PM
DanTana
Dec 6, 2006 05:05 PM
